Can anyone help . I broke a rear wheel tandem skewer 3 months agao , and i cannot find a replacement . A normal mtb skewer is just too short . I believe i require a 145mm skewer . It is a cannondale frame .
Guest Big H
Why did it break? We had one break while cycling. The rear hub seized and wound everything up and the skewer broke while stressed. At speed you may just get a verrrry bad taste in your mouth. Check and make sure.
We have Shimano Tandem Hubs on the Tandem. Contact Shimano directly at Coolheat tel no - +27 11 608 2003/ 0861 SHIMANO and ask for Stephen Meltzer. They should be able to help.
Broke when i put the rear wheel in . Thanks . will try them . The bike came with the wheels and hubs - Taiwan TX Quando .
Guest Big H
Contact Cape Cycle Systems (Pty) Ltd
Tel: 021 761 3528 | Fax: 021 761 5914
Lloyd Wright: | Graham Hall:
PO Box 151, Ottery, 7808, Cape Town, South Africa
They sell Ravo Tandems with those hubs
