If I view posts in "newest posts first order", then the permalinks function doesnt work properly
eg : if i click the permalink for post #3 and then go to that url, it takes me to post #3 on the last page
Am I making sense? :)
I'll look into both issues. I'd initially done a bit of a quick and dirty hack to put this in so expect it's just some silly logic.
Why after posting does it take a member back to the oldest post? :blink:
Hi guys,
Looks like it's sorted. Please test it out and let me know if there are any bugs creeping around.
Currently it's cookie based so if you login from a different PC or logout you'll need to set your post order again (it'll default to Oldest first). I plan to add a setting in your control panel so that you can set the default order and not have to select it each time.
Matt
Hi guys,
Matt
Testing…
And it works! Thanks! :D
