SRM & Campy 11 Speed Compact Crank ????
Does anyone know if SRM power meters do a 11 speed Campy Compact crank system - my LBS has mailed 'Activeworx' the local agents and they are of the opinion that you can't run compact cranks with a 11 speed campy SRM system (FSA Cranks)
This is the reply back from Activeworx - "Thanks for your enquiry with regards to SRM Training Systems. Find attached above more technical data and see below the specs and the prices of the FSA SRM systems which fill fit on his bike. Because he has a 11 speed , SRM recommends that he use the 10 speed chainrings which is a 53/39T chainrings.The compact 50/34T chainrings wont work so well with a 11 speed. "
If find this very difficult to believe.
