Hi guys, firstly will a ultegra front derailleur work fine with campy groupset.
Secondly:which crank is best to use with super record, fsa carbon pro team edition or carbon ultra torgue record, which is lighter and durable? I know that 11 spd chain will run on both of these 10 spd crank blades.
Thanks a lot!
The Ultegra FD should work OK with the Campag shifters if tuned properly. If you have one lying around, it'll be easy to set up and test. If you're buying a new one, why not go Campag from the start?
I would go for the Record crank:
  1. It will look better with a Campag groupset.
  2. They're about the same weight when measured with the BB, though Campag may be a bit lighter.
  3. FSA carbon cranks have been know to have durability issues.
Here's a crank comparison:
http://fairwheelbikes.com/forum/viewtopic.php?f=77&t=5991
