MAXXIS High Roller Tubeless 26 x 2.1
Hmmmm...
I used to run a Kenda Karma 26 x 2.2 on the front of my Anthem but it was worn and had a few dings so I changed to the Maxxis High Roller when I converted to my new rims (Gippieme Kenya XC - review to come later) after much deliberation and discussion with fellow MTBers and my LBS.
Now, the tyre is new so maybe I am being a little unfair but the grip that I was getting on Sunday through the single track at Holla Trails here in KZN was not very confidence inspiring. The pressure was a little on the high side though...
Does any one else on this BB run the High Roller upfront? What tyre pressure are you running and what is your view on the tyre?
I have a HR 2.3 up front and a 2.1 in the rear doing more all-mountain riding.
Coming of Nevegals, I can say they have SLIGHTLY less grip, but a lot less rolling resistance - will definitely keep them though, I run mine 22psi (round 1.5bar in front), weight 90kg and never suffered a pinch flat or even felt them give under aggressive cornering.
WRT the rolling resistance you are right, they roll much more efficiently than the Karmas as well... I guess that it is always going to be a trade off!
