hey..berry!
Well there's probably loads of previous forums on this, which you can search.
I recently moved from Ultegra to Sram Force (I assume you would want to be moving from 105 to Rival, or even Tiagra to Rival?).
Anyhow, the weight saving is definitely a bonus. Brakes pretty much the same, and the ergonomics of the shifters cool.
Shifting itself...well its a toss-up. I love the up-shifting on the Sram's double tap system and its very quick and smooth (i think smoother than ultegra), you almost can't feel it. The downshift a bit more tricky as you have to shift it a but further and use some "force"...and its not uncommon to mis-shift. On the Burger (my first race) I misshifted up (instead of down) twice. But its quick to recover so not huge issue, and with time you will probably get used to it. SRAM also makes a louder click sound when shifting down (I think only on front).
All in all - if its weight saving you're after (its a couple of 100 grams) and price - go for the Rival (which I`m told is not far off Force). If you want to keep things simple and easy, and have been used to Shimano, no real need to change.
I`m a happy Force user and weight saving helped me get my madone to 6.85kg...but I still have a soft spot for my old Ultegra!
Well for Ultegra you will pay a good couple of grand more than for Rival. So you would rather have to compare Ultegra to Force.
105 vs Rival, I would rather go for Rival. I must admit, that I upgraded while out of the country...rode the Force for first time for 15km on the Saturday before the Burger and then next morning the Burger. So I found it something to adjust too, but not overly difficult to get used to.
If 105 and Rival cost the same and Rival 900grams cheaper (i`m not sure about prices...only checked ultegra and force when I bought)...definitely the Rival!
Watch the Shimano guys crucify me now!
I have SRAM rival group set. Took about two rides to get used to.... But now its a pleasure all the way. Will buy SRAM again.......
