helo,
if you are looking to go for a lightweight BUT durabill rotor (160mm)...what would they plus minus weigh? Ive seen some scrub rotors on the net with a weight of like 43grams! How does these compare to some other top rotors? What brands do you guys use?
If you have a racing wheelset podium mmx's - what rotors would you put on?
I need some feedback here.
Hope Floating, XX, Formula R1 Rotors...all about 80g and durable enough.
I doubt it. Ashima makes some of the lightest discs and they only start at 85gr for the 160mm. They get branded as Alligator and Rav-X and are about R160 each
