nope mine is still stuffed, I tried refreshing.
Check the times of the "Latest Forum Post" on the left vs the "Active content" in the forum
Hi Tankman,
The active topics view seems to be a little buggy. There is usually a 5 minute lag between when content is posted and indexed in the Active Topics view. This means that sometimes there might be a mismatch between the Latest Posts window and the active topics view.
However, it does seem to be doing something odd today (I made some updates last night which are most likely causing it). I've noticed missing topics and incorrect ordering. I'll look into it.
In the mean time there's another view you can use which appears to be working properly. It shows all new content since your last visit: View New Content
Hi Tankman,
Morning Admin
I seem to have the same problem this morning ,is it still an issue or is the problem on my side ?
It's partially resolved.
The active topics page displays correctly when listing anything up to the last 12 hours (e.g. 15 mins, 4 hours, etc), but anything from 24 hours and above the ordering goes out.
As mentioned above the View New Content page appears to work fine.
Are you having the same problem described above? Which "in the last..." time period are you selecting?
