Hi there. Any of you clever okes know if SRAM makes a high mount, top pull, direct mount front deraileur in the XX range or only in the XO. Cant seem to find one.
Thx
The Sram direct mounts come in 3 mounts s1, s2 and s3, fyrther each one is either tooth specific either 39 or 42 and then the pull top or bottom.
It depends what frame you have which front mech will fit.
Thanks. Is the xo 10spd front and rear deraileurs compatible with the xx shifters?Long or medium cage for 10spd
I can't see why it wouldn't be SRAM uses the same pull ratio 1:1 so XO should fit with XX, but I don't feel its justified to run XX shifters with XO the cost isn't justified spec the XO shifters with XO derailleurs it will all look nice and balanced as XO comes in a host of colours.
LOng or short cage will depend on the bike and the amount of travel it has if any.
Regarding the front derailleur on the frame manufactures website it should say what front derailleur is compatible with the frame in question.
