Just started training with a power meter.
If I ride at average 270 Watts in a big gear for twenty minutes at 80% HR, will riding at a higher speed and cadence in slightly smaller gear but same power (270W) mean I am working harder during that interval - because my average heart rate might be at 88%
  • Replies 38
But doesn't a higher wattage mean that you are working harder?
Let me rephrase that - I could be working at a higher power output but lower heart rate
Imtb2007-11-20 10:26:27
This is an Efficiency question. Lower heart rate at the same output would indicate a good thing ! Means you can maintian that power for longer period. You heart rate basically tells you how fit you are ! if that make sense or is right then lucky me but i really know nothing mcuh about power about from matric physics
  Quote
Yea I would also think the higher your heart rate the better for training.
But you can work at a very high heart rate and spin all the way up a hill - at a slow pace and very little power
This is a very interesting question!  The simple answer is that watts are a direct measure of exercise intensity.  HR is a response to that intensity.  Note that you should not be going faster at the same wattage.  All things being equal (gradient, wind, rolling resistance, etc) the number of watts you are producing dictates how fast you go.
The complicated answer has to do with muscle composition.  For a given wattage (270 in your case) the higher the cadence, the lower the torque because power is calculated from torque x angular velocity (cadence).  As torque increases, so your muscles will recruit more fast twitch fibres so the power is produced by a different combination of muscle fibres when cycling with big gears or small gears.  Now, depending on your particular muscle makeup, this may be better or worse for you.  Plenty of research has shown that your body is good at selecting the cadence/torque combination which suits it best which is why there is a move away from previously held beliefs that high cadence is always a good thing (ala Armstrong).
[Edit]  The recruitment of more slow twitch fibres places more strain on the cardiovascular system because these fibres are oxidative, i.e.  they operate aerobically - hence HR will rise.
bruce2007-11-20 10:38:03
Okay I'm just trying to digest this - so if my interval is 20 minutes riding between 240 - 280 , riding in a really big gear to maintain that power is okay even if the speed is slower
  Quote
The speed will not be slower - watts are directly related to speed.  Gear combo's are irrelevant.
Just the cadence will be slower?
Imtb2007-11-20 10:41:24
Yes, sure - which is why I said in my original post "all things being equal"
Power is the rate of doing work.  So if you are lifting a mass against gravity it is a much greater force than wind resistance, so your power output is high even though you are moving slowly.  However, on the same gradient, wind, rolling resistance, the more watts you produce the faster you go.
