I need advice: I own a Gary Fischer Rig Single speed 29er, I love the bike and want to convert it to a geared bike....any advice? I suppose the biggest question is where to fit the rear/d ?
Jake! Jake the Snake - it's FISHER dude. As in FISH, with an er at the end. Like LegEND.
Is there not a hanger slot on the drive side with a filler?
If so, then you will need to locate a hanger to fit the slot. Have hanger, can convert.
Edited by The Drongo
You will have to see if a normal Fisher hanger is gonna fit the frame. Looks like it's the only tricky part.
I have an older bolt on Shimano Saint derailleur that should work. Have on for normal dropouts, which if it looks like the one above it will work. Also have one for horizontal dropouts.
Mamparaaa. If that is the back end of what he has, then GF should have a hanger to fit.
Other dude. I have a HONE bolt thru as well. They weigh a ton, and need a solid axle. Although you can convert a standard Shimano C&C from skewer to solid.
Beat to get a hanger, and a nice XT shadow rear D.
The hanger and XT shadow is first prize.
if you still have a problem, let me know and we can make a plan.
