Some competition for Mavic Cosmics wheels.These are a little heavier and arround the same price.
http://www.biketiresdirect.com/productimages/imageslarge/shr852-1.jpg
Material: rims: carbon/aluminum
spokes: stainless steel
Weight: 1831g (set, without quick releases)
Rim height: 50mm
Spokes: double butted aero spokes
Spokes number: front 16, rear 20
Over locknut distance: front 100mm/rear 130mm
Fitting type of tire: clincher
Fitting tire dimension: 622x15C (700C)
Fitting for shifting: Shimano 8/9/10-speed
"The rim construction starts with a reliable alloy braking surface which turns into a very thin aluminum skeleton as it continues into the rim section. Carbon fiber is then layered over the thin aluminum skeleton for weight savings and incredible stiffness and strength" *
In other words, a carbon sticker is placed over the aluminum rim?
* Source http://www.biketiresdirect.com/product/shimano-wh-rs80-c50-cl-clincher-wheelset
btw, absolutely no competition for Mavic wheels
