Hi guys... I use a iPhone 4 and endomondo pro when out MTBing... So I can track a heck of a lot...except my heart rate.
What device will be able to integrate with iPhone and endomondo to track my heart rate? Currently track my HR separately with a polar ft7....
Polar has a heart rate strap that makes use of bluetooth to connect. give that a try. There is another application (www.sports-tracker.com) that I use, but endomondo might have the same functionality. Let me know if it works.
Jannie
As far as I know, the Polar bluetooh transmitter is not compatible with the iphones
Sports Tracker is now available for i-Phone. Check with tech support at www.sports-tracker.com whether the polar bluetooth HR belt is compatible with the i-Phone. They are pretty helpfull, and efficient. I gort my polar HR belt from finland in less than 10 days with a 23% discount(EU vat). If you do the social networking thing........ try http://www.facebook.com/sportstracking
Good luck
  • 4 weeks later...
So far all I found that will work is the ant + transmitters that you can buy from endomondo,s site.... No one in sa seems to stock them... Big bummer as iwish Iyar a app for kyk hone that can track me like endomondo and incorp my hr as well...
  • 3 weeks later...
  • 5 weeks later...
If you want to use an ANT+ HR strap, you need an ANT+ dongle for your iPhone, like the Wahoofitness one (they also make an ANT+ bike case).
You can order them direct from Wahoo (postage is $20 and takes about two weeks) - https://www.wahoofitness.com/
CRC now also stocks them under the NC-17 brand.
Thanks... Who is crc?
Chain Reaction Cycles, a very big Ireland-based online retailer. Do a search here on the Hub and you'll find a lot of info about them. Also check out the online shopping sub-forum.
