Will 9 Speed trutativ Elita Crank work with 10 speed chain
Will 9 Speed Trutativ Elita Crank work with 10 speed chain ?
I have 9 speed dura ace crank running on 10 speed setup on my roadie and this works OK. Just not sure if you can do same with trutativ crank. If I even mention fitting any 9 speed crank on 10 speed setup my LBS thinks I'm crazy. This is for a TT bike I am building.
Qualified yes - but maybe no - in practice I don't know. 9 speed blades usually work fine on a ten speed set up but I had hassels with with 9 speed FSA cranks on a 10 speed. Chain occasionally skating on the small ring if changing while on the smaller sprocket sizes at the back. You'll have to try it.
