Hey guys
Just installed some new KEO 2 Max pedals. Using the provided cleats, there's quite a bit of left/right play on the pedal. I prefer a rigid 'grip' as this is what I had with my previous setup. Is this a 'tweakable' setting on the cleats? Or just how they are?
The cleats provided will give you 4.5deg's of float. I'd stick to them if I were you...they're designed to save your knees.
Ok, so I must just get used to the slightly "loose" feel?
That is correct - it allows your foot to 'float' and allows it to settle in it's natural position. This, as previously mentioned, saves you ligaments and will allow you to have pain free rides for years to come.... well that is unless you are pushing hard or take a dive of your bike. Then you will definitely hurt :thumbdown: but not because of the cleats :thumbup:
