Hey all you tech savvy hubbers, I have a question...
I recently bought a 2nd hand 2007 Commencal Meta 5.5. After some digging on the web, I have discovered that the shock length for the rear shock is 200mmx50mm. However, when measuring the shock currently on the bike, I discovered that its length is 190mm - it's a Rock Shox Monarch (where AFAIK the Meta originally came with a Fox RP23).
What are the effects of running a shorter shock? Can I get away with it or do I need to cough up for a new shock? Any and all advice will be appreciated...
You will loose some travel..... your head angle will slacken and your BB will drop a bit.
Don't think it is a train smash.....
Yeah the BB part's what worries me - this bike already has a low BB. Good to know it's not a train smash though - can save up and replace when the time is right rather than fork out now when I can ill afford it...
