I just lost a brand new ust tyre due to a nail...went in the tread and out the sidewall- the tread repair is easy - normal worms.. But the sidewall "cut/hole" is about 5mm in diameter - anyone with advice how to repair- want to use the tyre still for training - especially since it is a new tyre..
Patch it from the inside with a normal patch that you would use on a tube (or maybe a small piece of rubber cut out from an old tube) and then run it with a tube just to be safe?
Some guys sew the hole closed with dental floss. You could also patch it from the inside with a gator I guess.
I use waxed tread used for leather work and leather work needles to stitch up the hole. Then I patch the inside over the stitch work. And all done. You can even start making your own leather gimp suit kinky stuff. In silverton there is a leather supplier (leatherrite) for all your leather needs.
