Well, sort of.
Everything starts out fine, but after a few braking efforts, when I let go of the lever I can still hear that there is some rubbing for the rest of the ride.
What is the likely solution? :unsure:
probably just needs a good cleaning, the caliper that is, at worst, a service. First try to get the pistons back in properly, then exercise them a bit. if the sticking persists, might need to be serviced.
Also, check the rotor to ensure it's not bent as that can cause rubbing.
