No, it's not OK!
Correct frame size is non-negotiable for many different reasons.
A too small frame used for XCO riding will f-up your neck, back, knee's, etc... really, dont even think about it...
I just bought a bike and although I asked for a Large, the owner recommended a Medium reason being that it is a 29ner. I did the 50miler on the bike , but from a bout 50 km my shoulders and arms were absolutely killing me. This I did not bother me on the two trail rides (20km each) . That bike is covered in mud and I sit with a bike that is too small for me.
My first real bike ...........and it is too small.
Edited by Mads
I am really sorry to hear that Mads...
However, this happens every day, in way too many LBS..
ok, what size doyou recomend... ime 182cm. leg=87
You need a Large... and then you can play with the stem/bars/post to get your position/fit dialed in.
In more detailed you need a 19"-19.5" size, with a 600mm to 610mm top tube.
Edited by TheV
I am 183cm with leg 88 and my bike size is a Large
Your bike is a medium mads you need a L or xl
Edited by berry
You have very little to gain by buying a frame because it's a "great" deal but ends up too small for you...
Just don't do it, please!
which shop was it at?
I'm sure they can arrange something.
And in my case. Will it help to buy a longer stem? As my top tube is only 55cm
s0rry Mads....in your case specifically, the extra 1-2cm you can gain by a stem won't help much, and most probably just make it worse because even if it's more comfortable or a better "fit", it will just end up ruining your bike's handling and effect your descent/technical sections.
And if you take all of that into consideration then ride quality and better technical/rolling capability is what you got the 29er for in the first place?
What bike do you have?
GT Zaskar Elite 9ner Medium .........and not a Large
I used to ride a 2006 Giant Yukon and at this stage I think it might be better for me. I really struggled Saturday. In all honesty not ONLY because of the bike size ......But it played a major roll
Edited by Mads
Yes I am going to call the shop tomorrow.
