Hey! I have a blackburn with wireless speed. I don't know why but sometimes the speed just cuts out. I tried mounting the computer on sponge and it helped for a while but no longer. Has anyone else had this problem? Maybe I should put a double layer of sponge under it?Wacko
Tried that. Cant move it any higher? I have a feeling its to do with the vibrations coming through the stem? Like with the power taps?
Have you changed the battery in both the sensor and speedo? My Delphi did same thing and is now sorted out. I also moved the speedo a bit forward.
yes I tried that but didnt work? The magnet that came with the delphi broke so im using a cateye one. Do you think that could be a problem?
