Hi hubbers
Need quick advice which one to buy the Edge 800 of Forerunner 310XT or should I go for the Edge 500?
My previous unit was the Forerunner 305 so looking for a unit that can give me the same data or more interms of cycling.
There is R1200 dif between the 2 and thats why I can't decide.
It will only be used for cycling but I need a new unit that can give me power readings.
I need to have the unit on Monday.
Hi hubbers
Well if it is only going to be used for cycling purposes then the edge would be perfect
Go for the Edge 500
There are much more power data available with the latests software update.
Now 5 pages each with up to 8 data fields and on a quick tally last night 61 different options to choose what you want to display
