15mm Thru Axle QR Adapter Question
N-I-N-J-A
Hi Guys, I need some help/advice please.
I've got ZTR Crest Wheels with a Stan's 3.30 hub.
When I took my front wheel off over the weekend I realized that the rubber o-ring on the adapters/caps got pinched in the hub and was subsequently broken.
I know that the seals are there for a reason, but would I still be able to ride it without the o-rings if I don't ride in muddy/wet or dusty conditions until the weekend?
Link to comment
Share on other sites
just pop to the local hardware and see if they have an o ring that is suitable, should be a very easy swop.
Link to comment
Should be fine - just go to a irrigation or bearing/seals shop soon as you can to get a new one.
Make sure you clean out and re-grease once you have the new seals.
Link to comment
Thanks guys, I went to the hardware shop yesterday afternoon, but they didn't have the right size.
I want to go for a ride this afternoon though, and I don't want to stuff anything up if the seal is missing. Will go have another look over the weekend.
Link to comment
