AFAIK Quarq does not make a crank but a spider with rings. They dont have a Campy application listed let alone EPS. Option may be to get the Rotor/Quarq setup and slap on your Campy rings alternatively use Rotor Campy specific rings. Another may be to get a pedal based meter like Look to use with EPS cranks. Look pedal power meters work with Polar. You might lose your EPS warranty if you use a non -Campy crank. Goodluck.
www.lookcycle.com
http://www.quarq.com/store#store_home
Edited by MCipollini
