here you are, but I've never looked closely at either in real life, it just so happens I was looking at fitting discs to my hardtail:
Shimano Deore Disc Brake Front M525
http://www.chainreactioncycles.com/Images/Models/150/7884.jpgFeatures:
? Opposed piston design
? Strong stopping power with precision control
? Compatibility
? Locking caps on fasteners
? Adjustment reach levers
? Weight:Front:219g, Rear:224g
? 6 Bolt rotor
Shimano LX Disc Brake Dual Contol Front M585
http://www.chainreactioncycles.com/Images/Models/150/7888.jpgLight action, comfortable and responsive, M585 dual control system offers a pro-level command platform at an unbeatable price. Known for its durability and long term value, Shimano LX continues to be the components of choice for the price conscience, enthusiast.
Features:
? Twin piston Deore LX M585 brake calliper providing strong braking power with a minimalist design
? Mineral oil is non-corrosive and less hazardous than conventional hydraulic fluid
? Shim-less mounting bracket allows for quick installation and set up
? Compatible with international and post-type mounts
? 9 speed rear gearing with precise changing
? Braking and gear changing is possible simultaneously
? Allows shifting without moving hand position
? 6 bolt rotor mounting using a 160mm disc
Note, System comes Pre-bled and ready to install.
