Hi guys/girls.
So I got this protective sticker roll from Phat trikes but I'm not sure how to cut and stick it so that it wil cover the enrire fork including the "arch" so that it looks neat and no dust can get underneath.
Thank you.
Pieter
good luck!
your best bet would be to cut it in small pieces you will have edges that dust will get under...
and use a heat gun or hair dryer
good luck!
I was thinking it would come down to that. Thanks!
Spray the fork with water from a spray bottle, position the sticker, squeegee the water out, viola!
Edited by Mackie
Thanks guys. What I did was wrap paper around it and traced and then cut the stickers accordingly, I still need to do the arch tho. Neevous about that.
