I have the Led Lensers. There's bicycle Led Lenser but it seemed not suited to my needs and what i can use it for. I got the Led Lenser MT7 which is Pretty Good. Wide and narrow adjuster and best of all it has better running time and multiple use.
I have two mounted on my bicycle bars for perfect level for light flooded on the ground. One of these lights with max light can do full road but doesn't cover the sides . If i take one tilt it 20 degrees right then it covers half road and side of road same as the right side light.
|\ / \ / | Red Represents Light with 2 Torches: \ /
| \ / \ / | Black lines represent road: |
| \/ \/ | Dotted Line Represents Bicycle: ------
This is brighter when narrow see ahead easier
When it is more of the road flooded it gets dimmer but still bright but not detailed bright.
Is their another light with runtime of 2 hours and waterproof and has bright bright flood light to see the sides also as where i live animals and people run across and would be nice to notice before i get hit into any of these.
