On saturday after about 80km (just outside Malmesbury), my tyre went out of shape and had to stop.
It was pumo max pressure: 4 bar.
It looked like the one a golf ball popping out on the one side and the tire litterly at that point sat one side of the rim and just after the golf ball went to the ortherside of the rim.
At home I removed the tire and found that on the inside you get 'n "skin or layers" of wire thats attached to the rubber itself, and that had bubbles all in the middle of the tire.
Could it be that the pressure, and the way the tire grip on the road it got to much heat and the 2 came apart.?
Maybe because its a soft compound?
Gaan ruil dit om Poppaai..... oeps!!!!!! ......... jy sal dit moet terugpos!!!!!!!
Nee, oomH dis my phytons wat ek van verlede jaar het en dis reeds goed gebruik.
Ek het dit weg gegooi. maar ek dink dit kan wees dat omdat dit 'n sagte compound tire is, dat die grip van die teer dit bietjie te veel ge-message het en die layers laat los trek het in die binnekant.
My nuwes word eers volgende maand opgesit. Ek het nou daai crossmarks opgesit vir eers.
