Anyone know where I can have my rear wheel hub serviced (Crest 29er)?
Is there someone who is an agent in CPT area (preferably Northern Suburbs) that readily has the spares available?
I think that any good LBS will be able to do this. The Stans hubs are easy to service. I think it should only be the bearings that needs replacing and bearings are easy to get. My LBS serviced my Stans hubs.
They are very easy to service, you need two 6802 bearings. Very easy to get at about R70 max for the pair and even easier to replace yourself.
The FWB on the other hand is a little trickier as you can't get the job done without a bearing press.
