HI All
I need some help. I have a clicking sound when I pedal hard on my left crank. When I spin normally the sound is not there. Only when I pedal hard.
Anybody have an idea what it could be?
I had the same sound when I pedal hard but the sound was actually coming from my bb,my lbs told me that its from grit and water getting in the bb and when I pedal hard I experience the same thing , solution took my crank and bb off clean and greased it up and was good to go sound gone
I am getting the same thing on my spinning bike. Do you think it is BB or equiv....I am guessing it has one, have not pulled it apart......
  On 10/29/2013 at 8:42 AM, Bobbo_SA said:
Other option is your left pedal's bearings are shot, depending on the make and model you may be able to service them and replace the bearings.
Will try the bearings, if I can work how to get them off.
New?
If so, it will be hollowtech II
If a good few years old, hollowtech I
Either will set you back around R250 or so for the lower range ones.
Either way, you will need specialised tools to extract the cranks.
