I recently purchased a powertap, i have a garmin 500, which when i do the set up picks up the powertap etc, but when i ride its not picking up any readings, where do you think the problem may be?
thanks
I bought it 2nd hand and it worked for about a month! and now to show off my total ignorance I_BMC... replace the bateries in my garmin? or does the powertap also have batteries
The powertap also have batteries. In most cases you would need a special tool to open the thing up.
I should really get with the program of training with a power meter… but can anybody tell me what it would cost to have "any power meter" on my bike ? Im unsure what they start on really ?
and the batteries are different depending on which generation hub it is. which one is it? if its small and black its the newer which takes cr2032 batteries but if its the older one then its not the most common battery and might take a bit more time to find.
older : elite+,pro+
newer: g3,g3c
so far as i know they've stopped making the pro+ now but depends how old yours is..
its unusual for it to register on the garmin every time and then not work. does it work at all even for a few seconds? if it does then def suggests battery.
we have some ex demo units for sell starting from around R6500 however new pricing starts from around R9995.00
What all is included with the demo unit..? Are they built into a wheel or just the hub? also what hubs are they "G3,Elite+ etc.
iam looking for a 24hole do you have stock ?
best would be to drop me an e-mail on dave(at)bicyclepower.co.za and ill let you know what we have.
