Different calories burnt between Garmin Forerunner 310XT and Garmin Edge 810
Nalith
I recently went from using my Garmin Forerunner 310XT to log my rides to the Garmin Edge 810 however I seen massive differences in the estimated calorie burn between the two. The Edge unit is reporting 3x less than my Forerunner. I have checked and my profile is the same on both, anyone ever see this?
Link to comment
Share on other sites
In short:
The Forerunner uses an older type of caluculation of which the basis is duration of workout.
The Edge use a newer calculation, an algorithm based on averages that takes more variables into account (based on averages)
Link to comment
In short:
Lots of averages in there =) i.e. measurements not accurate at all...
Link to comment
As average as averages can be, that calculation is far more accurate than the duration based calc.
With the early duration based calc, you could switch your unit on (without even wearing your HR belt) leave it on your desk and disappear. Upon return 3 hrs later, you would have clocked 2500 calories or something stupid.
Keep in mind people differ any waaay too many variables needs to be taken into account, variables that a little computer on your handlebar is going to struggle to comprehend.
V02 max rates
Metabolism
% body fat
Fitness level
Whst you had for breakfast
CO2 absorption rates
Etc etc etc
I would still like to know what happens when you hit the stop button on your unit after a workout?
Dies your body automatically stop burning calories? No it does not!
So how much does it keep burning for how long after your workout ... and again we are back to a long list of variables!
The law of averages assumes that an unnatural short term balance will occur, hence all the avarages in the calculation!
:huh:
Link to comment
