Hi
Anyone know if i will run into issues if i powder coat the rim and then use it with v brakes ? Will it brake like normal ? Wear out ?
Will there be a way to get it powder coated without going over the brake line ?
Hi
There is a way to do that - but you need a good powdercoater or a dab hand with waterpaper.
Mask off the braking surface before you get them coated and you'll be fine. Otherwise you may as well put vaseline on your pads IMO.
Edited by droo
