  On 4/29/2014 at 5:16 PM, Ricardo_L said:
I am intrigued by this seatpost.
I have a carbon frame and my shifter lines run into the head tube and down the top tube. They seem to fit precisely into these holes.
I was wondering if it would be able to make the necessary adjustments to run the Reverb Stealth line through the frame and into the correct position for the internals.
Anyone with experience or suggestions on this?
If the lines run down the top tube then it ain't going to work.
If you can get them to run in the down tube, turn through the BB shell and up the seat post then you are winning.
You will obviously need to sacrifice one of the existing lines - so change to 1x drive up front or single speed the bike.
  • 2 weeks later...
