So i was swapping my pads out when I somehow managed to break the piston head off of my Juicy brake...
Does anyone know if its possible to get a replacement piston or would it just be easier to buy a new brake?
Yes I know its a very average brake but the bike is a commuter so nothing fancy is needed!
Cheers
I pushed the piston out one whilst bleeding mine. Luckily I was able to get it back in, but had to bleed the system twice to get all the air out. I'm sure you get replacement parts for them. But I think your LBS will have to order it.
Just replaced mine on the Juicy 3 as part of the seal change R155 per calliper set
The old pistons were very brittle probably from heat but almost seemed like a cast iron material where the pin that centers the pad
Where did you get your replacement parts? Can you give me Contact details?
Thanks!
