Hey Guys,
On my Easton EC90SL wheels, I've noticed that the rear wheel has a slight amount of 'play' from side to side.
Excuse the non-technical description, but I literally have no idea how else to describe it. I can't say I've noticed it while riding though but it definitely doesn't seem right.
Might this be an issue with the hub, the bearings or something else?
Wez-O
Edited by Wez-O
Okay, so to answer my own question, this video seems to clear it up...
It appears the bearing pre-load can be tightened.
I'm thinking I should probably get this done by a shop right?
You can do this yourself, but it will loosen up again. the wheels are fine with a bit of play apparently, stiffens up when you are on the bike... don't over tighten it..
Okay great thanks!
