Have a Xx
2x 10, 26-39 set up up front and
11-36 rear
my question is
can i use Sram Xo rear casette as a replacement with 1091R chain plus use Xo chain rings
i will like to eep the same gearing BTW
I have always had Shimano set up so this Sram thing is rather new to me
welcome input please
Dont know about the chainrings but the casette and chain works perfect. I run X9 Cassette and chain on my XX
Yes!
All chains and cassettes are interchangeable.
You could even run a shimano cassette and chain. Your derailers won't know whats what.
Its up to you what you can afford, I'll go for XT or X0 maybe X9 components. They are cheaper and last longer than the lower end stuff and not as heavy as the lower end stuff
Also if you have a XX crank the BCD is unique, BCD is the "spacing" of the bolts on the chainring.
You have to get 120BCD chainrings. So X0 wont work!
