Altitude difference between Polar and Strava
RABUBI
Picked up something interesting yesterday
Did a 60odd km ride yesterday
Use a Polar RCX3 that uses basically google maps to calculate elevation gain.
Total ascent 790m
Also used my Samsung to record the ride on Strava and total elevation gain is 928m
I thought that both uses google maps as a based to calculate elevation gain
Just funny that there is such a big gap
Any thoughts?
Im just quoting a guy from the webz:
"There are three ways (relevant, anyway) to get elevation data:
1) barometric pressure. Quite accurate if you have it, and calibrate it. Most folks turn on their computer and ride, which doesn't help that.
2) GPS. Crapton awful for elevation, for a variety of reasons, but essentially, a low-power receiver can't pick up a good enough constellation of satellites for the trigonometry to work out very well - especially from ground level.
3) read the GPS location data, then using topographic data, extrapolate and figure it out. Can either be decent or awful - for example, if you ride across a canyon bridge, this will assume you got your tires wet at the bottom - hella climb, though, buddy!
Strava uses 3. A higher-model Garmin uses 1, if you are patient enough to let it. Some websites (GC, mapmyride) will combine 1 and 3 and do some fuzzy math to try to get it as right as they can figger. Some toys use 2 to display random numbers while riding.
In other words, it's like the old saying. "A man with one watch knows what time it is, a man with two is never sure." Consider them all for crap - just pick one that suits you and go with it.
As long as it isn't Strava."
Have you noticed that when you finish a ride, Strava updates your distance and elevation after 5 minutes? It is a built in program to cross reference your route to the nearest available elevation maps (I don't think it is Google maps) and nearest available weather conditions.
But I am pretty sure ALL GPS tracking devices overshoot. The most accurate way of determing altitude is with a dumping level, because there aren't any engineers who build road-gradients using GPS values.
