BB Noise (external type)
johanpre44
I recently built up a bike (2 months and almost 600km ago). The only funny issue I have had to date is that the Bottom Bracket (external type that comes with a Shimano FC-M615 Crankset) is making a funny clicking noise. When it happened the first time I struggled to find the problem but eventually loosened and re-tightened the drive-side BB cup (think this was around 150km within 2 weeks). Now its happened again, but after a quick rinse (cleaning the worst mud off my bike) it went away and then just started again with the next ride.
My question is if there is a more permanent fix. I'm not sure if the plastic spacer on the drive side cup is causing the problem (maybe a metal spacer will work better).
My frame (steel) has a BSA threaded 73mm BB Shell, and I used copper slip on the thread before installing the BB cups. My BB tool is not the kind that can be used with a torque wrench so I have no idea how tight the BB cups have been tightened.
Try greasing your seatpost and your skewers as the creak may not always be the BB
Also check your pedals and make sure your rear wheel skewer is properly tightened
Is it a click or more like creaking?
For creaking when pedaling under load it could be squeaky clean BB spacers (give them a little grease when installing).
And as Fanie says, could be your pedals. Give them a service.
Check for loose chainring bolts.
Check rear axle - often the culprit for noises.
Do one issue at a time, then go for a ride before trying the next option. In other words, don't do a full service otherwise you won't be able to isolate the source. In time as you get to know your bikes quirks, you'll know immediately what the issue is when a noise starts up in the future.
