Lezyne pressure drive pump
KaKa
i bought this pump, nice performance and i like the hose system, no more broken valves. Great,
but this is a noise generator. i spent a lot of effort to get my bike as quite as i could now this pump is making so much noise (rattling)
anyone have the same experience. And what did you do to resolve the issue
A friend has one and it is a loose fit in that frame bracket. Can see it could be noisy. Try adhesive foam in the bracket and use the velcro strap to cinch it down.
Further investigation showed the hose and the handle is the cause of the rattling. I used a piece of inner tube around the pump body to hold the handle and a thin layer of silicon around the metal hose end. Will have to see if the solutions are clever
thanks for the advice bout the vales unscrewing
  • 3 months later...
