Crankbrothers freehub body replacement
JanJan
Hi Gents
I would just like to know if I can replace a Crank Brothers freehub body with a Shimano/SRAM one. They seem the same, but I dont know if they have different lengths and may cause fouling with the hub or frame.
The freebody will be fitted to a 10 speed SRAM cassette, which I've heard is 1mm -1.5mm longer than a Shimano cassette.
No can do. The pawls and how it conects with the hub are very different.
Edit: unless you are referring to a Crank Brothers freehub but for a Shim/Sram cassette in which case they are the same.
