Pyga oneforty 650 Pascoe Build Project
warawowo
Super excited to start building this awesome bike.
Will post some photos as I progress.
Already have
160mm Pike
Reverb stealth dropper post
Monarch plus rc3 debonair
Planning aggressive all mountain bike.
And wait to see what comes out!
  • Replies 76
Check the hole where the dropper hose comes out, just above the BB. I had trouble with building one as the hose just wouldn't go through the hole.
I had a big struggle as well. Used an old cable hose, put it through from the bottom.
Disconnected the reverb lever, used a thin strip of duck tape to tie the two together. . Eventually got it through.
Started first by disconnecting hose at the bottom of the post. That's supposed to be the easiest way but the connector did not fit through the hole
