Hope someone can help. have a RC6000 with the Campagnola 10 speed. It has a 11-23 casette on . Would like to know if it is possible to change to maybe 12-25 or anything bigger than the 23 . Not good enough to clime with 23. Where and what will it cost. Thanks
All bike shops should have a range of Veloce 10-speed cassettes.  You can get 12-25 or 13-26.  You will need to get a lockring as the 11 tooth lockring will not hold the 12 tooth.
Veloce cassettes are available online at:
http://www.sportsdirect.co.za/?Task=moreinfo&SKU=FW9413
http://www.icycling.co.za/store/comersus_viewItem.asp?idProduct=307
or from the UK:
http://www.ribblecycles.co.uk/details.asp?D=P&Cat=CASSETTES&Section=CASS&GenCode=CAMPCASS0450
You could also use a BBB cassette.  These are reasonable quality but do not last as well as the Veloce originals.  Again most bike shops stock BBB - if they don't change shops.
