Matt Posted February 23, 2015 Posted February 23, 2015 In an increasingly competitive action camera market the Rollei Actioncam S-30 WiFi puts up a healthy fight against other entry-level contenders. Click here to view the article
popcorn_skollie Posted February 23, 2015 Posted February 23, 2015 (edited) Did you use the bar mount with the camera inside the waterproof casing?Just curious if you did since I found the HP action cam tends to heat up which causes it to mist up inside Edited February 23, 2015 by popcorn_skollie
Matt Posted February 23, 2015 Author Posted February 23, 2015 Did you use the bar mount with the camera inside the waterproof casing?Just curious if you did since I found the HP action cam tends to heat up which causes it to mist up insideYes, I had it in the waterproof case. I didn't have any issues with misting up, but it wasn't very cold when I was testing it. I have seen this on other cameras, particularly when outside conditions are cold, e.g. early / winter rides, in water, etc. GoPro make anti-fog inserts which I've used in the past on other cameras - they work well and could be used with any camera. I'd think they'll all suffer similar problems in the same conditions (depending on how hot the camera gets).
Register a new accountSign in
