Rockshox XLoc Leaking
GP du Randt
I have a Rockshox SID fitted with the XLoc. The XLoc keeps leaking oil at the banjo fitting causing it to be locked out all the time. Can that be fixed by installing new rubber seals or should I just cough up a couple of bucks and buy a new damper?
Most likely a dud O-ring. Anton at Summit or Dave at Spoke and Spanner should be able to sort you out, otherwise PM me and I'll get it done for you.
