rockshox reverb dropper post for 2016 specialized camber 29
AJ Bam
I can't really comment on the new Command Post, but I'm not a fan of the old one, and there are certainly better ways of burning R 6k.
For cable actuated alternatives try the KS Lev Integra as Mayhem suggested, or the Giant Contact which can be either internally or externally routed - although it only has 100mm of drop.
For now, 100mm. Next year's has up to 150mm. That may be my replacement for the Reverb I have at the moment, as I've discovered I need more than the 125mm drop it offers...
  • 1 year later...
Hi guys
am loooking to buy a rockshox reverb stealth (internal routing) dropper seat post for a 2016 specialized camber comp 29er ali frame off chain reactions
need some advice!
you have to choose the specs of the dropper post and i dont know what to choose:
here are the specs for the camber:
seatpost diameter: 30.9mm
seatbinder: 34.9mm
seatpost length: 430mm
seat tube length: 468mm
so my question is, should i order the reverb according to the exact specs of seatpost diameter and seatpost length?
2nd question: will the reverb stealth be compatible with a camber?
there is an extra hole for a cable to feed out of near the headset but will this hole be big enough for the dropper post cable?
any help would be greatly appreciated
