Giant Anthem 29er bearing sizes / set
mtbride
Not all Anthems use the same size bearings.  Different year models differ slightly, especially in the upper bearings.
mmm ok thanks, mine is a 2014 X1 29 in any case. I'll report back if I find info on the net as well.
Best is always to have the parts in hand.  Check the bearing codes on the seals.  I have it on authority from a Giant agent himself that Giant uses only standard bearing sizes.
