Scalpel Si Shock Link Problems ?
spy
Hi All Scalpel Si Owners,
Have any of you experienced lateral play on the chainstay where it links to the Shock Link ?
I found the info on MTBR. Seems like it is tolerance issue than can be resolved by adding poly-lube and thereby
enabling the parts to "pull together" correctly . According to this post the factory is shipping the bikes with zero lubrication in this area.
http://forums.mtbr.com/cannondale/2017-scalpel-count-down-1006078-5.html
I hope this is not a design issue that is going to cause problems long term.
On the post it was mentioned that the HABIT has a similar issues.
See post # 226 , #230 , #277 , #279 , #283.
