Brake components from different manufacturers interchangeable?
Frank 84
My magura MT6 right lever cracked and is unable to hold any fluid, ive been quoted 3k for a new lever, cable and caliper. I was wondering if there was a cheaper way to fix this, or should i spend the 3k on a newish brake set?
CRC sells Shimano levers for 400 zar... the SLX ones a bit more. I have Magura calipers and SLX levers on a bike and they are super.
Just make sure that the levers you buy use compatible fluid. Ie. most later Magura and all shimano use Mineral oil while formula and Avid/SRAM use Dot fluid. Mixing those is not going to work.
