replacement pivot bolt
Mongooser
bent a pivot bolt on my canyon,the bolt came out the frame but is stuck in the ball bearing bit
and that cracked,so i took the linkage apart now i need a new bolt and bearing,how difficult is it to find pivot bolts and bearings that will fit my bike?
the bolts stuck in the linkage swing arm because its bent a bit and wont unscrew from bearing
