10mm axel conversion?
Mongooser
The demo 8 frame i want to buy takes a 10mm axel,my rapide has a conversion kit to go to 10mm QR
if i take the QR skewer out will the axel fit in hub? or do i need a new hub?
need to cover all the bases before i buy it
Measure the width of the hub from locknut to locknut. 10mm QR is generally 10 x 135mm, DH hubs are usually 10 x 150mm.
Not many 10 x 150 hubs out there anymore, but you may get lucky.
The 2012 demo 8 takes a 135mm 10mm bolt thru axel,I have a 12mm bolt thru 135mm hub with a 10mm QR skewer conversion kit
If it's 10 x 135 then you're good to go...
bingo,wont be a another week of wheel building.
Btw are race crowns on forks easy to find for a 2012 demos headset?
not sure if mine will fit.
There aren't a million flavours of crown race as long as it's a cartridge bearing, so I'm sure we'll find something without too much of a mission. For the 40?
if all goes to plan hopefully itll be fox 40,maybe a boxxer RC
